Convert ps to tiff
Steve Franklin franklin at ug.cs.dal.ca
Wed Aug 10 10:15:58 EDT 1994
Here's pstotiff which does a reasonable conversion job. It converts
to a ppm file, then from ppm to tiff. It requires ghostscript and
the pbmplus utilities.
   Steve Franklin
p.s. I can't be sure who to credit with this script. A good guess would be
that it came with the pbmplus utilities, but I'm not positive
#!/bin/sh
PATH=/local/bin:/usr/bin
export PATH
PROG=`basename $0`
if [ $# -ne 1 ]; then
	echo "usage: $PROG filename.ps"
	exit 1
fi
file=$1
base=`basename $file .ps`
/local/bin/gs -q -dNODISPLAY -dNOPAUSE /local/lib/ghostscript/pstoppm.ps <<EOI
($base) ppm8run
EOI
/local/bin/pnmtotiff $base.ppm 2>/dev/null > $base.tiff
/bin/rm $file.ppm
exit 0
