source vs binary
Cosyn Bart Bart.Cosyn at rug.ac.be
Fri Aug 19 01:39:01 EDT 1994
On Thu, 18 Aug 1994, Rica Saporta wrote:
> good day, again,
> as most of you have probably surrmized, i am no sys-op nor an expert in
> UNIX, but it has still fallen on me to install GRASS - an
> adventure i am looking forward to >:)
> i would really appreciate some help on these two wuestions:
> 1) as suggested by many of you i ftp'd GohstView in the form
>    of the file gsview11.zip: here is the rub, what is a zip file?
>    I have tried moving the file to DOS and using PKUNZIP, which
>    is the only thing i could think of, but PKUNZIP dosen't
>    know what to do with the expanded files (litteraly) so it
>    aborts.  any thoughts (i didnt use UNCOMPRESS because its not
>    a .Z file)
Transferring files to a dos pc needs mentionning the format, so put while
ftp'ing your format to binary and look for the volume of the file you
transferred. I never had problems to uncompress afterwards by pkunzip.
Try to get a new version of pkunzip.
					Bart
     Ir. Bart Cosyn
     Laboratory of Hydrology & Watermanagement
     Fac. of Agricultural Sciences and Applied Biological Sciences
     University of Gent
     Coupure Links 653
     B-9000 Gent
     Belgium
     Tel +/32/9/264/61/37
     Fax +/32/9/264/62/36
     E_mail:Bart.Cosyn at rug.ac.be | or bcosyn at allserv.rug.ac.be
