ps.map postscript
BAKERWL at uwyo.edu BAKERWL at uwyo.edu
Fri Feb 4 12:47:32 EST 1994
Some time ago there was a discussion about the postscript produced by
ps.map.  The problem was that the ps.map postscript files could not be
read in by other programs.  I generated a postscript file with the new
version of ps.map from grass/incoming, then tried to load it with xv,
but xv will not recognize it as an image file.  The header in the
ps.map postscript file does indicate "%!PS-Adobe-3.0 EPSF-3.0" which
suggests it is an encapsulated postscript file.  Was this problem ever
resolved?
	Bill Baker
	bakerwl at uwyo.edu
