Environment Variable
Davide Frisoni frisoni at faw.uni-ulm.de
Fri Feb 25 05:08:49 EST 1994
Hi grass-users & programmers,
in a C application, I set variables (monitor coordinate and dimension, mapset
and location) to new values with G__setenv(), but nothing change! :-|
I try to use G_setenv(), that modifies env file, but I have the same result!!:-(
In the second way the env file has modified, then I try to restart G_gisinit():
NOTHING, NOTHING and NOTHING!!!!!
Could someone help me to change _truely_ the GRASS Environment run-time?
Thanks in advance for your suggestions.:-)
					--FRY
Davide Frisoni                      |  e-mail(internet):
Forschungsinstitut fuer anwendungs- |  frisoni at faw.uni-ulm.de
orientierte Wissensverarbeitung FAW |
Helmholzstr. 16                     |  Tel.:  +49-731-501 8626
D-89081 Ulm, Germany                |  FAX:   +49-731-501 999
