Converting ascii data to GRASS4.1 format - continued
S. E. Walker guernsey at holstein.age.uiuc.edu
Fri Feb 25 16:26:49 EST 1994
	With help from several of you, I was able to convert
ascii x,y data which defined the boundary of an area to a GRASS
map using v.import.  Now the question is:  is there a way to
read in a category number along with the x,y coordinates defining
the boundary or must one go through v.digit or manually create
a dig_att file to label the bounded areas?
	Thanks again for any advice.
Sharyl Walker
Department of Agricultural Engineering
University of Illinois
