let's standardize sites
Simon Cox simon at artemis.earth.monash.edu.au
Sun Jan 23 11:02:34 EST 1994
> So far am I knowing of Helena's work from UNIBA they are even using about
> 5-7 labels (original and derivated parameters) for 1 site... a standard
> format should allow more than one label per site if needed...
> F. Hoffmann
Now I see this, I agree that this is also not such a bad idea.  Then the
s.programs will just need some way of addressing the required attribute field,
($1, $2, ... etc? - an "awk-like" solution to the weak site-database
capabilities of GRASS.)
Simon
___________________________________________________
      __  L     Dr Simon Cox
   ,~'  L_|\    VIEPS Department of Earth Sciences,
,-'         \   Monash University, Clayton Vic 3168
(            \  Australia
\    ___     /          Phone +61 3 905 5762
 L,~'   "\_x/           Fax   +61 3 905 5062
           u    simon at artemis.earth.monash.edu.au
