r.in.tiff woes.
Steve Franklin franklin at ug.cs.dal.ca
Tue Jun 14 14:01:35 EDT 1994
Good afternoon,
   A bug has seemed to pop up in grass now, that was not there before. I had
previously used r.in.tiff without any problems, but now am running into
Memory fault - core dumped... Somewhat puzzling. Here's what happens, even
though identical runs used to work fine...
GRASS-GRID > r.in.tiff input=jello.tif output=blah
( d.rast blah works fine on the raster file "blah" )
GRASS-GRID> ls -l core
-rw-r--r--  1 franklin  8507824 Jun 14 14:51 core
Has anyone seen this before?
Here is the verbose output of r.in.tiff:
 > r.in.tiff -v input=jello.tif output=blah
Reading jello.tif...TIFF Directory at offset 0xb15a
  Image Width: 256 Image Length: 192
  Bits/Sample: 8
  Compression Scheme: Macintosh PackBits encoding
  Photometric Interpretation: palette color (RGB from colormap)
  Orientation: row 0 top, col 0 lhs
  Samples/Pixel: 1
  Rows/Strip: 32
  Planar Configuration: single image plane
  Color Map: (present)
  6 Strips:
      0: [       8,     7260]
      1: [    7268,     7700]
      2: [   14968,     7736]
      3: [   22704,     7873]
      4: [   30577,     6573]
      5: [   37150,     8252]
256x192x8 image
 8 bits/sample, 1 samples/pixel
 256 colormapped
 Creating SUPPORT Files for blah
done.
I hope someone has run into this problem before...
   Steve Franklin
