continued heartburn over r.in.tiff
CSCI2662 at CL.UH.EDU CSCI2662 at CL.UH.EDU
Sat Jun 18 19:29:11 EDT 1994
	Having read your E mail I went in and did the same thing that
was said. ie convert to a sunrast format using xv and then doing a
r.in.sunrast. The conversion was fine but when I got the image onto
the monitor all I get was a blank screen. I then tried to run the
r.in.tiff and it said that the command was not found.
	My research is mainly to convert a collection os tiff and giff
files and bring it up on grass. Please help my with the following.
a) Where do I get the r.in.tiff command file
b) Do you guys know of any utility program that can convert from
   giff and tiff files to the grass formats.
Please do not ignore this E Mail. Since we are working on a similar
problem let us try to help each other.
Thanks
