tutorials
    Steffen Meyer
    steffen at longs.lance.colostate.edu
    Fri Jun 24 19:03:22 EDT 1994
In message <01HDXDX4NBZM000614 at UHCL2.CL.UH.EDU> you write:
> 	I got the file grassman.wp but I am unable to read it. Is it a
> word perfect file. How cn I read it
> Shameek
The file is a PC-DOS WordPerfect file.  Move the file to PC or
workstation with WordPerfect.  ftp is simplest, be sure to use bin
If you are working on and do not have a networked PC iyou can still
produce PC-DOS compatible text and binary file from Sun equipment.
There is a useful utility to copy small files using the 3.5" floppy drive
to /from Sun/PC called mtools.
  The command would be mcopy grassman.wp a:
To get mtools
ftp to max.cecer.army.mil
  cd mtools
  dir files
  bin
  prompt (once only to toggelof prompt)
  get README
  mget mtools*
  quit
Once you have the file on a pc, you should be able to use WordPerfect
to read and print the file.  I ws successful.  Note that the ftp
does not respond to the dir or ls command.  Rob Fraser assured me
to use his instrcutions and have success.
Good luck
Steffen Meyer
steffen at longs.lance.colostate.edu         tel: 303-491-7620
Integrated Decison Support(IDS) Group     fax: 303-491-2293
Colorado State University, Fort Collins, Colorado 80523 USA
