continued heartburn over r.in.tiff
CSCI2662 at CL.UH.EDU CSCI2662 at CL.UH.EDU
Fri Jun 24 19:57:29 EDT 1994
	I tried your method of converting the tiff file using XV version
3. I then used r.in.sunrast to import the file. All I got was an emty file.
The file size reduced from 315611 to 48 bytes. I tried it again with a
seperate file. The result was still the same. No matter how large the file
is it reduces to 48 bytes.
	Can you think of a reason as to why this happens. Thanks
