PhotoCD & UNIX? - PCD to TIFF?
David Haight davidh8 at pogo.wv.tek.com
Wed Mar 9 20:13:03 EST 1994
Gee, I just joined the list and already I can reply to a question.
I joined as a "friend of GRASS users" and will have a few questions of my
own soon.  I am a Technical Support Applications Engineer for the color
printer division of Tektronix.
The QUESTIONS from Ronald Thomas (ront at meeker.cfnr.colostate.edu)
>1)      Can a PhotoCD be mounted on a UNIX system?  If so, how?
>	(I tried the standard "mount -r /dev/sr0 /cdrom", but no luck
>	-- is it a specific file system type that needs to be noted?)
>	I can attach the CD to either a SPARCclassic or an IPX.
You can mount a PhotoCD as iso9660.  Be warned though, if it is a multi-
session you will only be able to read the first session.
>2)      If # 1 is possible, can I just copy the *.pcd files I want to my
>	SPARCclassic and use as they are, or do I need to run "dos2unix"
>	on them?
You can copy them or you can just convert off your CDrom drive to your
hard disk.
>3)      Is there a PCD to TIFF converter around, perhaps as a new addition
>	to the PBMplus toolkit?  (I'd like a straight, hi-resolution
>	conversion of the PCD format to TIFF)
I use a routine, hpcdtoppm, I'll include the man page for iman page for it
at the end of this.  I use it on an SGI Indigo and I'm not sure if I still
have the source but the author's email address is in the man page and I know
I got it off the net.
>4)      Is there a UNIX (SunOS 4.1.3 or Sol 2.2) viewer of Kodak
>	PhotoCD's, or a program that views/reads/converts the
>	*.pcd format?
This one I don't know for sure.  The SGI now has a viewer.  You might check
the latest version ov XV (3.0 I think).  You can certainly use XV on the
result of the conversion with hpcdtoppm.  I'm pretty sure you can make hpcdtoppm
available to XV.
The man page follows at the end of this.
David Haight
Tektronix Technical Support
800-835-6100 x 7354
hpcdtoppm(1)             USER COMMANDS               hpcdtoppm(1)
NAME
     hpcdtoppm v0.4 - convert a Photo-CD  file  into  a  portable
     pixmap
SYNOPSIS
     hpcdtoppm [options] pcd-file [ppm-file]
DESCRIPTION
     Decodes a Photo-CD Image file or Overview file.  Image files
     you  can  find  on the Photo-CD in photo_cd/images, they are
     named as "imgnnnn.pcd", where nnnn is a 4-digit-number.  The
     Overview  file  is at photo_cd/overview.pcd . If there is no
     output filename given, output will  be  printed  to  stdout.
     hpcdtoppm  stands for "Hadmut's pcdtoppm" to make it distin-
     guishable in case someone else is building  the  same  thing
     and calling it pcdtoppm.
OPTIONS
     -x   Overskip Mode.  Works  on  Base/16,  Base/4,  Base  and
          4Base. In Photo-CD images the luma channel is stored in
          full resolution, the two chroma channels are stored  in
          half  resolution  only and have to be interpolated.  In
          the Overskip Mode  the  chroma  channels  of  the  next
          higher  resolution  are taken instead of interpolating.
          To see the difference, generate one ppm  with  and  one
          ppm  without  this  flag.  Use pnmarith to generate the
          difference image of these two images. Call ppmhist  for
          this  difference  or  show  it with xv (push the HistEq
          button in the color editor).
     -s   Apply simple sharpness-operator on the Luma-channel.
     -d   Do  not  show  the  complete  image,   but   only   the
          decompressed  difference.   It  works only on the 4Base
          and the 16Base resolution. It does not have any  deeper
          sense, but it was simple to implement and it shows what
          causes different sizes of image files.
     -i   Give some information from the fileheader to stderr. It
          works   only  for  Image  files.  (It  is  not  working
          correctly, just printing some strings.)
     -m   Show the phases of decoding to stderr.
     -crop
          Try to cut off  the  black  frame  which  is  sometimes
          scanned at the image borders. The image size shrinks.
     -pos Print the file relative start position of the data  for
          the current resolution.
     -rep Try to jump over reading errors in Huffman code.
Sun Release 4.1    Last change:  16 March 1993                  1
     -n   Don't rotate the image.
     -r   Rotate the picture clockwise for portraits.
     -l   Rotate the picture counter-clockwise for portraits.
     -a   Try to find out  the  image  orientation  byself.  This
          doesn't work for overview files yet. It is very experi-
          mental and depends on one byte. Please tell  me  if  it
          doesn't work.
     -vert
          Vertical flip.
     -hori
          Horizontal flip.
     -rgb Write rgb image in IRIS RGB format.
     -ppm Write rgb image in ppm-format.
     -pgm Write grayscale image in pgm-format.
     -ycc Write ycc image in ppm-format.
     -ps  Write rgb image in postscript.
     -eps Write rgb image in encapsulated postscript.
     -psg Write grayscale image in postscript.
     -epsg
          Write grayscale image in encapsulated postscript.
     -pl f
          Set left position of Postscript image to f.
     -pb f
          Set bottom position of Postscript image to f.
     -pw f
          Set width of Postscript image to f.
     -ph f
          Set height of Postscript image to f.
     -c0  Don't correct the image.
     -c-  Do a correction (darker). Hardware and taste dependend.
     -c+  Do a correction (brighter). Hardware and  taste  depen-
          dend.
Sun Release 4.1    Last change:  16 March 1993                  2
     -1 | -Base/16 | -128x192
          Extract the Base/16 size picture (size 128x192 pixels).
          Note that you can only give one size option.
     -2 | -Base/4 | -256x384
          Extract the Base/4 size picture.
     -3 | -Base | -512x768
          Extract the Base size picture.
     -4 | -4Base | -1024x1536
          Extract the 4Base size picture.
     -5 | -16Base | -2048x3072
          Extract the 16Base size picture.
     -0 | -Overview | -O
          Extract  all  pictures  from  an   Overview   file.   A
          ppmfilename  must be given. If the given name is "foo",
          the files are named "foonnnn", where nnnn is a  4-digit
          number.   Since they are stored in Base/16 format, they
          are extracted in this format.
     -C d Extract  all  pictures  from  an   Overview   file.   A
BUGS
     hpcdtoppm seems to  ignore  the  read  protection.  :-)  The
     informations  i  have  are  quite vague and this program was
     developed by  starring  at  the  hex-dumps  and  the  famous
     trial-and-error-method.  If  anything  doesn't  work, please
     send me a report and perhaps you could try to find out,  why
     it doesn't work.
SEE ALSO
     ppm(5), ppmquant(1), ppmtopgm(1),  ppmhist(1),  pnmarith(1),
     ppmtorgb3(1), xv(1)
AUTHOR
     Copyright    (c)    1992,    1993    by    Hadmut    Danisch
     (danisch at ira.uka.de).  Permission to use and distribute this
     software and its documentation  for  noncommercial  use  and
     without fee is hereby granted, provided that the above copy-
     right notice appear in all copies and that both  that  copy-
     right notice and this permission notice appear in supporting
     documentation. It is not allowed to sell  this  software  in
     any way. This software is not public domain.
Sun Release 4.1    Last change:  16 March 1993                  3
