digitizer
Ken Sibley ksibley at ncg.scs.ag.gov
Tue Mar 22 16:56:32 EST 1994
> From grass-lists-owner at max.cecer.army.mil Tue Mar 22 13:10:11 1994
> Date: Tue, 22 Mar 1994 11:30:10 -0700 (MST)
> From: KATHDOYL at uwyo.edu
> Subject: digitizer
> Sender: grass-lists-owner at max.cecer.army.mil
> Reply-To: grassu-list at max.cecer.army.mil
> X-Vms-To: IN%"grassu-list at max.cecer.army.mil"
> Mime-Version: 1.0
> Content-Type> : > TEXT/PLAIN> ; > CHARSET=US-ASCII>
> Content-Transfer-Encoding: 7BIT
> Content-Length: 434
> Hi Grass users,
> I am trying to set up our CALCOMP 9500 digitizer to our SUN station. The baud
> rate is 9600 and the data bits are 8 bit.  I looked at the list of available
> digitizers in the etc/digitizer/ file.  How can I tell if any of the digitizers
> on the list correspond to the digitizer that we have?  For example, what does
> cc95f23_16 mean?  Any help that you might be able to provide will be
> appreciated.  Thanks, Kathy Doyle
Kathy,
If you view the files in the digitizers directory there is a description of the format
being used for that file at the top of the file.  There is also more information listed
in the programers manual (Ch. 21).
Summarizing for those without the programmers manual:
The naming conventions for digitizers driver files is:
21.4 Digitzer File Naming Conventions
	manufacturer name or abbreviation + model number of digitizer + output
	format the digitizer is using + _ + number of keys on puck
Ken Sibley
USDA-SCS
