more digitizer
Ken Sibley ksibley at ncg.scs.ag.gov
Wed Mar 23 15:26:36 EST 1994
> Thank you to Malcolm Williamson and Ken Sibley for responding to my
> question about setting up the CALCOMP digitizer.  I think we figured out
> which available digitizer we need "cc95f6_16",  however it also appears
> that we need a subdirectory in the etc/dig_drivers directory corresponding
> to the digitizer and that we need to change the ownership on this to "root".
>   Our dig_driver directory has only 2 subdirectories "kurta" and "kurta2".
>   What do we need to do to get an appropriate  subdirectory set up?   Also
> am I missing something, or can I assume that setting up the subdirectory in
> the dig_drivers directory will be the last step, assuming the "cc95f6_16" is
> the correct format for our digitizer?
> Thanks for any light you may be able to shed on this issue.
> Kathy Doyle
Kathy,
I beleive that the dig_drivers directory is not needed.  From what I know the dig_drivers/*
files are for the old v.digit, ie. pre grass4.1, now called v.digit2 in grass4.1.
If someone else knows more about this feel free to explain/correct where needed.
Ken Sibley
USDA-SCS
