s.db.rim and RIM problem
Student Acct 0 s0 at aldo.tmc.edu
Thu Mar 24 16:14:01 EST 1994
Please let me know if you hve used s.db.rim to open a database created in RIM?  The database was exported to a text file and then imported for use with the
s.db.rim command. The imported database is listed as available; however, I
can't open it. The error message is RIM ERROR CODE #1: Unlisted Rim error
message.
   Thanks.
   Sharon Des Rosiers, Applications Systems Analyst
