more digitizer
KATHDOYL at uwyo.edu KATHDOYL at uwyo.edu
Sat Mar 26 15:37:23 EST 1994
From:	IN%"grassu-list at max.cecer.army.mil" 23-MAR-1994 14:19:22.80
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
To:	IN%"grassu-list at max.cecer.army.mil"
CC:
Subj:	RE: more digitizer
Return-path: <grass-lists-owner at max.cecer.army.mil>
Received: from max.cecer.army.mil by PLAINS.UWYO.EDU (PMDF V4.2-12 #5576) id
 <01HABBXG1TY8000UGX at PLAINS.UWYO.EDU>; Wed, 23 Mar 1994 14:17:29 MST
Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA15969
 (5.67a/IDA-1.5 for <KATHDOYL at PLAINS.UWYO.EDU>); Wed, 23 Mar 1994 15:13:54 -0600
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1) id
 AA00159; Wed, 23 Mar 94 14:33:57 CST
Received: from zorro.cecer.army.mil by max.cecer.army.mil with SMTP id AA15138
 (5.67a/IDA-1.5 for <grassu-people at max.cecer.army.mil>); Wed,
 23 Mar 1994 14:33:56 -0600
Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id
 AA22834 (5.67a/IDA-1.4.4 for <grassu-people>); Wed, 23 Mar 1994 14:33:52 -0600
 AA00133; Wed, 23 Mar 94 14:33:49 CST
Received: from ncg.scs.ag.gov (ncg01.ncg.scs.ag.gov) by max.cecer.army.mil with
 SMTP id AA14969 (5.67a/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Wed,
 23 Mar 1994 14:26:58 -0600
Received: from gss01-gw.ncg.scs.ag.gov by ncg.scs.ag.gov (4.1/SMI-4.1) id
 AA02600; Wed, 23 Mar 94 14:26:56 CST
Received: from gss03.ncg.scs.ag.gov by gss01-gw.ncg.scs.ag.gov (4.1/SMI-4.1) id
 AA13686; Wed, 23 Mar 94 14:26:36 CST
Date: Wed, 23 Mar 1994 14:26:36 -0600 (CST)
Subject: RE: more digitizer
Sender: grass-lists-owner at max.cecer.army.mil
Precedence: Bulk
To: grassu-list at max.cecer.army.mil
Reply-to: grassu-list at max.cecer.army.mil
Message-id: <9403232026.AA13686 at gss01-gw.ncg.scs.ag.gov>
Content-transfer-encoding: 7BIT
Precedence: Bulk
> Thank you to Malcolm Williamson and Ken Sibley for responding to my
> question about setting up the CALCOMP digitizer.  I think we figured out
> which available digitizer we need "cc95f6_16",  however it also appears
> that we need a subdirectory in the etc/dig_drivers directory corresponding
> to the digitizer and that we need to change the ownership on this to "root".
>   Our dig_driver directory has only 2 subdirectories "kurta" and "kurta2".
>   What do we need to do to get an appropriate  subdirectory set up?   Also
> am I missing something, or can I assume that setting up the subdirectory in
> the dig_drivers directory will be the last step, assuming the "cc95f6_16" is
> the correct format for our digitizer?
> Thanks for any light you may be able to shed on this  > Kathy Doyle
>Kathy,
>I beleive that the dig_drivers directory is not needed.  From what I know the dig_drivers/*
>files are for the old v.digit, ie. pre grass4.1, now called v.digit2 in grass4.1.
>If someone else knows more about this feel free to explain/correct where needed.
>Ken Sibley
>USDA-SCS
>ksibley at ncg.scs.ag.gov
 I still am not able to get our digitizer set up.  While v.digit works when I
select "none" for a digitizer, v.digit2 does not work.
We are using have grass4.1.
I am stuck.    It seems like there could be a number
of reasons why I can not get the CALCOMAP 9500  digitizer to  work.  Our
manual did not provide much information, so I am not confident that I am using
the correct format statement.  Does any one have any  clarification about
which format statement to use and why v.digit2 will not work for me.  Thank
You.  Kathy Doyle
