DLG import
Joyce A. Nagle nagle at rsgisc.crrel.usace.army.mil
Tue May 17 10:19:37 EDT 1994
I am importing a DLG-3 file that I created using ARC/INFO to GRASS4.0/4.1.
The A/I coverage I used has 5 points so the DLG-3 file has 5 degenerate
lines.  I have used the v.import command and the v.in.dlg and v.support
commands.  With v.in.dlg I get nodes = 5, areas = 0, lines = 5, unknown =
0, degenerate lines = 5.  Then with v.support I get number of lines, nodes,
areas, atts, etc. = 0.  And, of course, I get the same thing with v.import.
 Consequently, no points imported.
Help!!  Any suggestions how to get points from the DLG-3 file to GRASS
using these commands.  I am not interested (at this point) in using the
ungenerate format.
Thanks in advance.  Please send your comments directly to me and I will
summarize and put the answer(s) out on the listserver.
Joyce A. Nagle, Ph.D.
U.S. Army Corps Of Engineers Remote Sensing/GIS Center
72 Lyme Road                           phone:  (603)646-4161 FAX:  (603)646-4750
Hanover, NH  03755-1290       e_mail:  nagle at rsgisc.crrel.usace.army.mil
