No subject
Susan Stitt susan at its.nbs.gov
Mon May 23 11:42:28 EDT 1994
>Date: Mon, 23 May 1994 13:12:44 MET-DST
>From: Pierluigi.Bonfanti at Dpvta.Uniud.It
>Subject: R.SURF.CONTOUR and real numbers
>I have used R.SURF.CONTOUR to produce a DEM.
>Now I need to export the file with R.OUT.ASCII,
>but I'm unable to obtain an ascii file with real
>data type.
>Is it possible to produce a DEM with real data type
>(with 2 decimal numbers) by using R.SURF.CONTOUR,
>or must I transform the units of the input file
>from meters to centimeters?
>Thanks.
>Alessandro Fregonese
Alessandro,
Floating point capabilities with GRASS are being worked
on by the Army Corps of Engineers, but are not currently
available.  You will need to transform the units from
meters to centimeters if you wish to keep that level
of accuracy.
Good Luck!
Susan Stitt   National Biological Survey  sstitt at its.nbs.gov
              Technology Transfer Center  (303)969-2596
