GRASS to ERDAS
James Darrell McCauley mccauley at ecn.purdue.edu
Mon Oct 24 07:48:04 EDT 1994
John Nugent (ng240 at ursus.pnl.gov) writes on 23 Oct 94:
>Is there a program that converts GRASS raster files to ERDAS raster files?
yes. Depending upon what version of the format you have,
r.in.erdas in src.contrib/SCS may work. Otherwise, you
must use 'dd' to strip off the 128 byte header and use i.tape.other.
I recently had a file in 7.3 format (BIL) and had to use
the latter procedure. r.in.erdas needs to be modified to
work with this format.
--Darrell
James Darrell McCauley, Purdue Univ, West Lafayette, IN 47907-1146, USA
mccauley at ecn.purdue.edu, mccauley%ecn at purccvm.bitnet, pur-ee!mccauley
http://soils.ecn.purdue.edu/~mccauley
