Remove small polygons
Trond Rinde
trinde at donau.boku.ac.at
Wed Sep 7 12:58:20 EDT 1994
Hello!
I have a raster map consisting of 1000 sub-areas of different category values.
Ca. 980 of the sub-areas are so small that I want to remove them, and set their
category-value equal to that of their surrounding areas. I want to remove a lot
of small "spots" to achieve a more uniform map of only ca 20 subareas.
Can someone give a hint about the easiest way to do this.
Thank you in advance!
Trond Rinde
Siv.ing. Trond Rinde
Institut f. Wasserwirtschaft, Hydrologie und konstruktiven Wasserbau
Universitet f. Bodenkultur
A-1190 Wien, Nussdorfer Laende 11
tel: 1 36 92 924 352
fax: 1 36 92 924 350
email: trinde at donau.boku.ac.at
