ftp GRASS
Brian Buckley buckley at ig0.rs.msu.edu
Fri Sep 9 09:13:03 EDT 1994
> Hi
> On Fri, 9 Sep 1994 aprc at mail.nerc-bas.ac.uk wrote:
> >  I have found it impossible to ftp from moon.cecer.army.mil from PCs, although
> > there is no problem from Workstations. My local support people conjecture that
> > this is because our PCs are not DNS registered, while the workstations are. This
> > means that if moon.cecer.army.mil attempts to check on the existence of the PC
> > systems, it can't find them in the DNS system, and refuses to connect to them,
> > for security reasons.
> > Can someone confirm or deny this hypothesis?
> Well it depends what the real problem is. You don' get connected or is he
> denying your access eventhough the port is opened. I he refuses indeed to
> open the port that is indeed the reason. Can you make with your pc a
> telnet session on an external workstation outside your local network
> If not I confirm your problem and than you have to ftp over
> the workstations if they are connected with the pc. Inform me about it,
> maybe you can save by this needless searching!
> 				Bart
>      Ir. Bart Cosyn
>      Laboratory of Hydrology & Watermanagement
>      Fac. of Agricultural Sciences and Applied Biological Sciences
>      University of Gent
>      Coupure Links 653
>      B-9000 Gent
>      Belgium
>      Tel +/32/9/264/61/37
>      Fax +/32/9/264/62/36
>      E_mail:Bart.Cosyn at rug.ac.be | or bcosyn at allserv.rug.ac.be
Hello,
I can ftp to moon.cecer.army.mil from my pc.  It is a gateway 2000 486.
I'm at Michigan State University, I'm on ethernet and I'm running PCTCP
by FTP Inc.
Hope this info helps you locate your problem.
:-) Brian Buckley
P.S. I don't believe that the dns on campus has this pc listed on it.
