v.digit problems: STILL
Janne Soimasuo jsoi at gis.joensuu.fi
Thu Sep 15 08:41:54 EDT 1994
Hi !
The problem with linux and v.digit is set_key.c-file. With linux you should use
some bsd-stuff. Furthermore you have to add -lbsd when linkng v.digit
There is still something wrong with linux and digitizing boards:
It works once (if it works at all) with same post configuration.
(/dev/ttyS0 etc.). If you try to use it another time the programs stops.
I donno if it is v.digit or linux which causes this problem.
Here is the set_key.c-file I got from Andy Burnett
(I posted this to D. Gerdes also)
Hope this helps you !
* Janne Soimasuo            *     phone +358-73-151 4519                       *
* GIS & RS lab.             *     fax   +358-73-151 3590                       *
* Faculty of Forestry       *                                                  *
* University of Joensuu     *     email janne.soimasuo at joensuu.fi              *
*                           *           jsoi at gis.joensuu.fi                    *
* P.O.BOX 111               *                                                  *
* FIN-80101 JOENSUU         * "There never enough time to do all the nothing   *
* FINLAND                   *  you want"  Calvin                               *
set_key.c:
**  US Army Construction Engineering Research Lab
**  Written by GRASS 3.0 Summer of 88,  -mh
*  This file includes
*	set_keyboard()   -  set the keyboard up for key_hit()
*	unset_keyboard() -  set the keyboard back to original mode
*	key_hit()	 -  will try to read a character from the keyboard.
*			if a key has been hit and it is placed it in the passed
*			in the buffer and a true value is returned.
*			if no key has been hit return false 0.
#include	<bsd/sgtty.h>
#define		KEYBOARD	0
set_keyboard () {}
unset_keyboard () {}
int
key_hit(buf)
	char	*buf ;
	int	Keyhit ;
	if (ioctl (KEYBOARD, FIONREAD, &Keyhit) < 0)
		printf ("\nioctl failed") ;
		close_down(-1) ;
	if ( ! Keyhit)
		return (0) ;
	Get_curses_char(buf) ;
	return (Keyhit) ;
*	nodelay() is only on the 3B2.
#ifndef  USE_TERMIO
#endif
#define		KEYBOARD	0
set_keyboard ()
	return (0);
unset_keyboard ()
	return (0);
int
key_hit(buf)
	char	*buf ;
	int	status ;
	if (ioctl (KEYBOARD, FIONREAD, &status) < 0)
		close_down(-1) ;
	if ( ! status)
		return (0) ;
	return (status) ;
