Trouble to install Linux Grass 4.1
cjchen at students.wisc.edu cjchen at students.wisc.edu
Tue Apr 18 12:39:28 EDT 1995
In Message 18 Apr 1995 16:42 CDT,
  cive1em at rosie.uh.edu (Chuang, Lu-chia) writes:
>I have trouble to install grass 4.1 on Linux.
>I didn't know how to use "ginstall", so I used the following commands
>"cat grassa? | *************" to install. (sorry, I forget rest of it).
>Anyway, this command extracted a lot of files into directory "/usr/grass".
>Few minutes later, the extraction stopped. I received a message :
>"pipe break" (or "pipe broken"). Any idea?
>I downloaded my linux grass 4.1 from moon.ceder.army.mil.
>Is it possible some of the archive files are bad?
>Any suggestion is welcome.
>Luke
I have no idea what happened in your case but as I remember, you can just
type "sh ginstall" then the installation srcipt will ask you which directory
you want to install GRASS.
I downloaded GRASS binary files from moon.cecer.army.mil 7 months ago but I
delete all of them because I am doing several projects which need some
GRASS programs written by Purdue and Oklahoma universities. According
original author said I need to download GRASS source code and recompile
those programs with it. Anyway, the command I mentioned above should work,
at least it worked in my case several months ago.
| Chan C. Chen                                                |
* University of Wisconsin - Madison                           *
| Civil and Environmental Engineering                         |
| TEL: (608)257-9156                                          |
* Email: cjchen at students.wisc.edu                             *
|        chan-chi at cae.wisc.edu                                |
*        chan-chi at caelab1.cae.wisc.edu                        *
