SunOS 5, GNU gcc and GRASSv4.1.5
Andy Burnett burnett at diego.cecer.army.mil
Tue Apr 25 15:10:10 EDT 1995
In info.grass.user you write:
>have to buy one seperately apparently), so we are thinking of using using the
>GNU freeware gcc C compiler.
>Has anybody any advice on this - I don't want to start getting into any
>situations detrimental to my mental health (I used to be a Physical Geographer,
>where did I go wrong?).
  I compiled grass 4.1.x under linux using gcc.  The only problem that I
ran into was that you need to compile with -fwritable-strings in the
CFLAGS variable for gmake. (In certian parts of the code literal strings
are modified which is a no-no by default for gcc).
Good luck.
				&y
