Mapset copy
Rick Thompson rick at cast.uark.edu
Fri Aug 11 08:00:00 EDT 1995
Hi Joe,
  For vector data you can use v.transform from x,y coords to known UTM coords.
Images in x,y can be rectified into UTM. Rick
On Fri, 11 Aug 1995, Joe Leone wrote:
> Hi all,
> I have two seperate location  each with a mapset which I would like to
> combine. The mapsets represent the same geographical area. The problem
> I encounter is the projections are different.
> I would like to copy mapset remnant into location kellerberrin and be of
> projection UTM.
> Can anybody give me some help?
>   Mapset <remnant> in Location <Kell10m>
>   GRASS 4.1 > g.region -p
>   projection: 0 (x,y)
>   zone:       0
>   north:      4626
>   south:      1
>   east:       5051
>   west:       1
>   nsres:      1
>   ewres:      1
>   rows:       4625
>   cols:       5050
>   Mapset <study> in Location <kellerberrin>
>   projection: 1 (UTM)
>   zone:       50
>   north:      6544241.72
>   south:      6497873.03
>   east:       595050.72
>   west:       544136.64
>   nsres:      10.03
>   ewres:      10.08
>   rows:       4623
>   cols:       5051
> Thanks
> Joe
> Joe.Leone at per.dwe.csiro.au
Rick Thompson-   Research Specialist          E-mail: rick at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-8498
Ozark Hall Rm. 12                             Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
