projections in GRASS
Admin. scarab J.M. ROQUES 5322 scarab at cisi.cnes.fr
Tue Feb 28 04:40:42 EST 1995
Hola Vincente,
Aqui viene una responsa a lo que preguntes.
Fue "mailada" ayer, desde belgica por algo similar. era en mi correo esta manan
a.
Hasta la proxima vez
JM Roques
> As Grass is not transformable from f.i Non-projected data to Lambert
> Conic projection I am a bit afraid you will need to combine own written
> programs with the Grass tools for image processing. i.points and i.rectify
> I had a basically identical situation to transform my data to the Belgian
> Lambert projection.
> I wrote a program that allowded me to calculate points from one system to
> another. This you should be able to get from a local geographic institute
> or at least you would need to have the refernce points and meridian.
> After having written this you should do the following.
> Make a group with i.group so in this way grass creates the subdirectory
> group and a subdir with the name of the group. Normally using i.points or
> i.vpoints you create a file POINTS. You can skip the module i.points and
> create the file POINTS yourself with your calculated data. Then just run
> i.rectify. Be sure that you have good distributed points over the area.
> It should work but it will take time to develop your own transformations!
>                       Bart
>       | ir. Bart Cosyn                                  |
>       | ERS1/2 project                                  |
>       | Laboratory for Hydrology and Water Management   |
>       | University of Gent                              |
>       | Coupure 653, B-9000 Gent                        |
      | Belgium                                           |
>       | Tel: +/32/9/2646137                             |
>       | Fax: +/32/9/2646236                             |
>       | E-mail: bcosyn at allserv.rug.ac.be                |
