Fragstats code available
Milton Ribeiro mribeiro at carpa.ciagri.usp.br
Thu Feb 9 04:41:53 EST 1995
Hi Jim:
	What's Fragstat?
Miltinho (RIBEIRO, M.C.)
Quantitative Methods Laboratory
Forest Science Department
ESALQ/University of Sao Paulo
Brazil
On Wed, 8 Feb 1995, Jim Hinthorne wrote:
> To all:  Today I put the source code and the *.ps manual files on the moon
> server as /grass/incoming/fragstats1.0.Z
> This is a compressed tar archive.  You can compile only the raster version
> which will process GRASS rasters.  Prior to using fragstats you must
> uncompress the grass raster file (r.compress -u) into a raw file.
> The source code has compiled cleanly on several different systems here.  It
> is not a grass program, so it can be put anywhere on your system.  I believe
> you have to run the command
>   make -f Makefile
> to start the compilation.
> Good luck.
> Jim Hinthorne                        Voice: 509-963-2826
> GIS/Geology                         FAX:   509-963-1047
> Central Washington Univ.       E-mail: geol1 at cwu.edu
