FRAGSTATS
Randall Downer biosas at netcom.com
Thu Feb 9 15:08:54 EST 1995
>I would also like to know what is fragstats ?
>Nalneesh Gaur
>From the Idrisi FAQ:
         FRAGSTATS is a spatial pattern analysis program for quantify-
       ing landscape structure.  The raster version of  the  program
       will read IDRISI image files (the vector version is  for  use
       with ARC/INFO coverages).  FRAGSTATS generates area  metrics,
       diversity metrics, and contagion and  interspersion  metrics.
       A PC version of the program,  along  with  documentation,  is
       available via anonymous FTP at  FSL.ORST.EDU.  FRAGSTATS  can
       be found in the PUB directory.  Be sure to read the README.PS
       file and the documentation in the MAN directory; installation
       and operation instructions can be found in the  FRAGSTATS.DOC
       file in the raster and vector directories.
Further it should be noted that version 2.0 is out .
Rt 1 Box 391                                 919-968-1960 (FAX)
Pittsboro, NC 27312                          919-968-0824 (VOICE)
