here is v.plant
Simon Cox S.Cox at solo.ned.dem.csiro.au
Fri Feb 10 01:10:20 EST 1995
Sorry folks - I seem to be having some difficulty accessing moon (at least
I cannot read anything in "incoming" so here is v.plant.
----------------------- cut here ---------------------------------------------
#!/bin/sh
#	fills in intermediate points on vectors
#	if the point spacing is greater than a threshold
#	it uses the dig_ascii format as an intermediate step and replaces the original file
#	sjdc 10/2/95		s.cox at dem.csiro.au
if [ ! "$GISRC" ]
then
	echo "Sorry - you are not running GRASS">&2
	exit 1
fi
echo	""
echo	"v.plant fills in intermediate points on arcs with a specified spacing"
echo	"Take care:  the original file is replaced with the new one"
echo	""
echo	"Simon Cox,  CSIRO,	10/2/95"
echo	""
eval  `g.gisenv`
: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
g.ask type=old prompt="Select a vector (dig) map to process" element=dig desc=vector unixfile=/tmp/$$
. /tmp/$$
rm -f /tmp/$$
if [ ! "$name" ]
then
	exit 2
fi
if [ $mapset -ne $MAPSET ]
then
	echo "Sorry - you can only do this operation to maps in the current mapset"
	exit 3
fi
echo ""
echo "Enter a number for the minimum spacing of points on arcs (in map units)"
echo ""
gotit=0
while [ $gotit -eq 0 ]
do
      echo -n "spacing:  "
      read space
      if [ $space -ge 0 ]
      then
              gotit=1
      else
              echo "Sorry, spacing must be non-zero"
      fi
done
# remove existing dead lines
v.clean $name
# write dig_ascii file
oname=${name}.old
v.out.ascii input=$name output=$oname
# cd to dig_ascii and process ascii file
cd ${GISDBASE}/${LOCATION_NAME}/${MAPSET}/dig_ascii
nawk -v thold=$space '
BEGIN{
i=0
if(NR<15){	print $0; next;	}	# pass header info through unchanged
if( $1 ~ /^A|a|L|l|S|s/ ){		# found new object header
	if(i){				# write out previous object
		print objecttype,i
		for(j=1; j<=i; j++)	print " ",y[j],x[j]
	objecttype= $1; 		# initialise for new object
	i=0;
	if( objecttype ~ /^a|l|S|s/ ){	# dont interpolate for sites or dead objects
		print $0; 		# pass these through unchanged
		skip=1;
	else	skip=0;
	next;
if( skip ){	print $0; next; }	# pass data through unchanged & move to next line
i++; y[i]=$1; x[i]=$2;			# read coords into x,y array
if( i<2 )	next;			# if this was first coord move to next line
ydist= y[i]-y[i-1]			# measure distance to last point
xdist= x[i]-x[i-1]
dist= sqrt( ydist*ydist + xdist*xdist )
if( dist > thold ){			# fill in intermediate values
	n_intervals= int( dist/thold )
	y_increment= ydist/(n_intervals+1)
	x_increment= xdist/(n_intervals+1)
	y[i+n_intervals]= y[i]
	x[i+n_intervals]= x[i]
	for( j=1; j<=n_intervals; ++j ){
		y[i]= y[i-1]+y_increment
		x[i]= x[i-1]+x_increment
		++i
END{					# write out last object
if(i){
	print objecttype,i
}' $oname > $name
# only remove dig file - we want to preserve to atts and cats etc.
rm $file
# load processed file
v.in.ascii input=$name output=$name
v.support map=$name
#tidy up
rm $name ${name}.old
echo "Done"
