converting .SIT grass vector files
Coleman Catherine yc5763 at sunams.usma.army.mil
Fri Feb 10 09:15:50 EST 1995
Kevin,
>Hi,
>We are using a GPS system to make UTM co-ordinate measurements of a site.
>The software which comes with the GPS system is able to output it's data
>in what it calls a grass vector format. These files have a .SIT extension
>on them. How can this format be imported into grass? (the software is now
>2 or 3 years old). If this data could be imported directly into grass it
>would be extremely helpful to our project.
I have recently loaded .sit files into GRASS and used them as site files.
I loaded them (ftp) over a local network from the PC with the GPS software on
it.  You can edit them on a PC if it's easier for you, then transfer them
directly into your site_lists folder in GRASS.  (you can tar them in from a
disk as well) The format I used sometimes had a header on the file and
sometimes did not. It seems to work both ways.  This is an example of the file
I transfered.  You can imediately use d.sites and they will show up on your
monitor.  To list them with their labels you must have both the cat# and a
label name.
For example:
name|C:\PFPRO\DATA\PFINDER\SNAKES\S110317A.COR
desc|S111620C
579166.620|4575969.899|01|324.220
578979.581|4576117.185|01|313.885
578865.345|4576298.503|01|247.736
This is the original file from the GPS software.  I loaded it into GRASS and,
using vi or any other text editor, I changed it to the following format.
name|snakes.sit
desc|male
579166.620|4575969.899|#1 loc1
this is:
name|(filename)
desc|(file description)
easting|northing|#cat label
As I said before, I have used site files without the name and description
header and they worked just fine.
Hope this is helpful.  It's pretty easy once you do it once.
Catherine
Catherine H. Coleman
Natural Resources Branch, DHPW      Ph:   914-938-5939
U.S. Military Academy               Fax:  914-938-5453
West Point, NY  10996               email: yc5763 at westpoint-emh2.army.mil
