grass can't find rle programs
Malcolm Williamson malcolm at cast.uark.edu
Fri Feb 17 10:35:07 EST 1995
Bill,
First, check under $GISBASE/etc/bin/contrib/cmd to see if the executables
actually got put there. Assuming that they did (I checked the Gmakefiles for
r.le to make sure they do that!), the only other possibility I can think of is
that you had GRASS up and running while you compiled the programs. If that is
the case, you'll need to issue a "rehash" command so that the PATH is checked
for new programs. That's all the ideas I've got!
> Any help would be appreciated.  I compiled the r.le programs, ran
> MAKELINKS.sun4 (I`m on a sparc system), but grass is unable to find
> the r.le programs.  The compilation and the linking script seemed to
> run cleanly.  Anyone have any ideas as to what I am missing.
> Thanks
> Bill Mahoney
> wmahoney at gsd.harvard.edu
Regards,
Malcolm D. Williamson - GIS Specialist           E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
