FW: grass can't find rle programs
Zhian Li zhian_li at agcs.cas.psu.edu
Fri Feb 17 10:08:18 EST 1995
_______________________________________________________________________________
Subject: RE: grass can't find rle programs
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
Hi There:
    I think the problem is that you have not run the setup script( normally in
 /home/grass directory, you may have to check where is it on your system)
after
 you recompiled the source program.  This script sets up the soft links in the
 file front.end to the load modules in /grass/bin, to which the executables
have
 been put when you compiled you source code.  Hope this is helpful. Good luck.
      Zhian Li,  RCWP water quality group at Penn State.
From: grassu-list at moon.cecer.army.mil on Thu, Feb 16, 1995 18:35
Subject: grass can't find rle programs
Precedence: Bulk
To: grassu-list at max.cecer.army.mil
Any help would be appreciated.  I compiled the r.le programs, ran
MAKELINKS.sun4 (I`m on a sparc system), but grass is unable to find
the r.le programs.  The compilation and the linking script seemed to
run cleanly.  Anyone have any ideas as to what I am missing.
Thanks
Bill Mahoney
wmahoney at gsd.harvard.edu
