HP650C
Malcolm Williamson malcolm at cast.uark.edu
Thu Jul 6 16:06:14 EDT 1995
You learn something new every day!! Have you used this successfully? What
is the acceptable domain of color names (standard GRASS colors?), and is
this command sensitive to placement in the scripts?
	-Malcolm
On Thu, 6 Jul 1995
dgc at cast.uark.edu wrote:
> Hi Malcolm,
> 	I do know that you can use the command "setcolor [category] [color]"
> in your ps.map script to change the color of your categories.
> 		Don
