tiff to GRASS
Zorka Zegarra R. viewps at llareta.dagh.uta.cl
Sun Jun 4 10:35:46 EDT 1995
Hello:
Valerio wrote:
>Dear Grass Users,
>J am a GRASS beginner....
>J have tried to import a TIFF-file in GRASS with the command
>"r.in.tiff".
>Here is the entire results:
>#r.in.tiff input=x.tif output=y.tif
>Warning, TIFF directory is missing required "StripByteCounts" field, calculating from imagelenght.
>Reading x.tif.....TIFF Directory at offset 0xf416
>Subfile type: (0=0x0)
>Image widht 7200 Image Lenght 6646
>Resolution 300, 300 Pixels/Inch
>Bits/sample:1
>Compression Scheme: CCITT Group 3 facsimile encoding
>Photometr. Interpretation: min-is-black
>Samples/Pixel:1
>Rows/Strip:6646
>Planar configuration: Single image plane
>Group 3 Options: (0=0x0)
>1 strips:
>        0: [             24,         62462]
>ERROR: Only handle 1-channel gray scale or 3-channel color.
>J have tried to change Compression Scheme and resolution but with the same results.
>J have then converted the TIFF file in GIF format and used the command "r.in.gif" but it seems  this command doesn't work (the result is "no match").
>Is it possible to replace this only file and where can j find it?
>Sorry for bad english.
>Valerio
is probable that isn't compile, so that must addd the path where is in
the file src/CMD/lists/GRASS and compile...
you can find the comand r.in.gif in ..etc/bin/contrib/cmd/r.in.gif
good Luck!
AH! ... and excuse my english, is'n t very good
Zorka Zegarra R.
Depto. Ingenieria Computacion e Inf.
& Depto. Geografia
Universidad de Tarapaca, Chile
e-mail:viewps at llareta.dagh.uta.cl
