Set up GRASSLinks:97
Zorka Zegarra R. viewps at llareta.dagh.uta.cl
Tue Jun 6 12:05:07 EDT 1995
					June, 05 - 1997
Hi'
Is intented to set up GRASSLinks, but to appear the following error:
sh: no home directory ERROR: MAPSET grasslinks1 - permission denied
when run displayer1 in the line:
case $GREGION in
        predios at PERMANENT)
        g.region rast=$GRASTERi
every times that run one the grass comand appear the some error.
If run grass.cmd and run the grass comand like "g.gisenv" not put problems
why???
if display the environment value the grass in displayer1 have:
echo $LOCATION_NAME
echo $GISRC
echo $MAPSET
echo $GISDBASE
echo $GISDBASE
echo $LOCATION
> valle
> /utilitar/pub/html/viewpsXI/.grassrc
> grasslinks1
> /usuarios/decom/viewps/grass
> /usuarios/decom/viewps/grass/valle/grasslinks1
You will can orientate me ....
the advancing much thank you
 Zorka Zegarra R.
 Depto. Ingenieria Computacion e Inf.
 & Depto. Geografia
 Universidad de Tarapaca, Chile
 e-mail:viewps at llareta.dagh.uta.cl
