bringing in point data from ARC
Simon Cox S.Cox at solo.ned.dem.csiro.au
Thu Jun 29 08:00:00 EDT 1995
>Notice that this process puts the record number into the attribute
>column in GRASS, which may or may not be what you want.  You may need
>to create another file of the attributes and then add it onto the
>first column of the .lab file in place of the $recno, or as the third
>column of a post-awked file.  This would require some minor perl
>programming or a good editor.
The Unix command "paste" can be combined with "awk" to accomplish similar.
Simon Cox
___________________________________________________________
Dr Simon Cox                          __  \
CSIRO Exploration & Mining         ,~'  L_|\    Australian
39 Fairway, PO Box 437,         ;-'         \   Geodynamics
Nedlands, WA  6009  Australia   (            \  Cooperative
      Phone +61 9 389 8421      +    ___     /  Research
      Fax   +61 9 389 1906       L~~'   "\__/   Centre
simon at ned.dem.csiro.au                     W
AGCRC info>>   http://www.dem.csiro.au/simon/crc/intro.html
