changing cell resolution
Malcolm Williamson malcolm at cast.uark.edu
Tue Jun 27 08:00:00 EDT 1995
On Tue, 27 Jun 1995, GREEN WILLIAM G wrote:
> Last week I asked about increasing the 25 cell limit in r.neighbors because
> I needed to look at an area beyond the 25 cells (i.e., 10,000 ft.).
> I found that rather than changing the source code (which I am technically
> incapable of doing), I could simply increase the resolution of each cell
> from 25 meters to 200 meters.  The question I have is when you increase a
> cell's resolution, what value does it use.  For example, does it use the
> existing value of the center cell or does it average all of the cells that
> it is incorporating.
Hi, Bill
GRASS uses "nearest neighbor" resampling. Thus, if you were resampling from
5 meter to 25 meter resolution, resulting in an odd number of "old" cells
fitting in your "new" cells, the value of the center "old" cell would be
assigned to the "new" cell. If you were resampling from 5 meter to 50 meter
resolution, resulting in an even number of "old" cells per "new" cell, the
value in the UPPER-LEFT cell of the CENTER FOUR "old" cells would become the
value assigned to the "new" cell.
Hope that makes sense to you! Regards,
Malcolm D. Williamson - GIS Specialist           E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
