mayday (m'aidez) our monitors are sick
Ronald Wiemer RWIEM at archis.nl
Thu Mar 9 03:46:10 EST 1995
> Received: from SpoolDir by ROB (Mercury 1.13); Wed, 8 Mar 95 22:58:34 +0100
> Return-path: <grass-lists-owner at moon.cecer.army.mil>
> Received: from sol10 by hercules.archis.nl (Mercury 1.13);
>     Wed, 8 Mar 95 22:58:25 +0100
> Received: from ginko.cecer.army.mil by sol10 (5.0/SMI-SVR4)
>     id AA04831; Thu, 9 Mar 1995 00:56:57 --200
> Received: (from daemon at localhost) by ginko.cecer.army.mil (8.6.9/8.6.9) id NA
A06793 for grassu-people; Wed, 8 Mar 1995 13:06:10 -0600
> Received: from max.cecer.army.mil (max.cecer.army.mil [129.229.20.254]) by gi
nko.cecer.army.mil (8.6.9/8.6.9) with ESMTP id NAA06790 for <grassu-list at ginko.
cecer.army.mil>; Wed, 8 Mar 1995 13:06:08
> 0600
> Received: from hermes.aston.ac.uk (hermes.aston.ac.uk [134.151.79.46]) by max
.cecer.army.mil (8.6.9/8.6.9) with ESMTP id NAA05798 for <grassu-list at max.cecer
.army.mil>; Wed, 8 Mar 1995 13:00:56 -0600
> Received: from sun.aston.ac.uk (actually host hawaii.aston.ac.uk)
>           by hermes.aston.ac.uk with SMTP (PP); Wed, 8 Mar 1995 19:05:16 +000
0
> From: charnotw <charnotw at helios.aston.ac.uk>
> Date: Wed, 8 Mar 1995 19:03:49 GMT
> Message-Id: <13343.9503081903 at sun.aston.ac.uk>
> Sender: grass-lists-owner at moon.cecer.army.mil
> Reply-To: grassu-list at moon.cecer.army.mil
> Precedence: Bulk
> To: grassu-list at max.cecer.army.mil
> Subject: mayday (m'aidez) our monitors are sick
> X-Sun-Charset: US-ASCII
> Content-Length: 1229
> X-PMFLAGS: 33554560
> We have an epidemic of monitors failing.
> basically they lock up and become totally unresponsive
> even if you completely logout and start up GRASS again
> you just get the message:
> GRASS 4.1 > d.mon start=x0
> Graphics driver [x0] is already running
> Warning - no response from graphics monitor <x0>.
> Check to see if the mouse is still active.
> ERROR - no response from graphics monitor <x0>.
> Problem selecting x0. Will try once more
> Mapset <watertables> in Location <shropshire>
> GRASS 4.1 >
> stopping them produces a response:
> GRASS 4.1 > d.mon stop=x0
> Monitor 'x0' terminated
> GRASS 4.1 >
> but they can still not be started (same message as above)
> I've only lost the use of x0 but other people have lost
> x1 and x2 (we'll run out soon!.
> We have been using GRASS for ages and this has only just
> started, anybody got any bright ideas?
> cheers  Tom  8-)
> Tom Charnock                       O--O
> Dept Civil Engineering            (~~~~)
> Aston University                 (  __  )
> Birmingham B4 7ET UK             /|\  /|\
> charnotw at sun.aston.ac.uk
I presume you are running the message queue version of the
grass monitor. I you do, you can use the following script
********* begin *********
NAAM=$1
if [ "$NAAM" = "" ]
then
    echo "Usage: KillX username"
    exit
fi
eval `ipcs -aq | awk '{if ( $5 == NAAM ) print "PID=" $13 }'
NAAM=$NAAM`
for P in `ps -e | awk '{if ( $4 == "XDRIVER" && $1 == PID) print $1}'
PID=$PID`
do
    kill -9 $P
done
for i in `ipcs -aq | awk '{if ($1 == "q" && $5 == NAAM) print $2}'
NAAM=$NAAM`
do
    ipcrm -q $i
done
******end*******
The problem with these MQ's is that the Xdriver keeps running when
it's out of sinc. the script kills the Xdriver, and -very important-
removes the MQ's. You have to run the script (as user root) for each
user that has a hanging Xdriver. You can check wether your system
uses MQ's by running the program:
ipcs -aq
See the man page for ipcs.
Succes
Ronald Wiemer
