Compilation problem (Solaris)
mike camann camann at pick.uga.edu
Thu Mar 30 17:38:40 EST 1995
Sorry if you get this twice, but I posted it to grassp-list as well as
grassu.
When compiling GRASS 4.1 (update 5) on a Sun SPARC 20 under Solaris 2.4
(? it's SunOS 5.4) I get the following compiler error shortly after
starting GISGEN:
cc -O -Xs -DGETHOSTNAME_UNAME -I/gis-soft/grass4/src/include  -c
intr_char.c
"intr_char.c", line 17: incomplete struct/union/enum tchars: buf
"intr_char.c", line 19: undefined symbol: TIOCGETC
"intr_char.c", line 20: undefined struct/union member: t_intrc
cc: acomp failed for intr_char.c
make: *** [OBJ/intr_char.o] Error 2
GISGEN failure at STEP: src/libes/gis
Take a look at $GIS/src/libes/src/intr_char.c.  The incomplete struct
and the undefined symbols refer to definitions that should be found in
<sgtty.h> when  #ifdef USE_TERMIO is undefined, as is the case on my
system. The <sgtty.h> file in SunOS 5.4 is VASTLY different, however,
from the one in SunOS 4.1.1, where I have successfully compiled GRASS
many times (and where this particular preprocessor directive works
fine).  That's /usr/include/sgtty.h.  Under SunOS 4.1.1, tchars and
TIOCGETC are actually defined in <sys/ttold.h>, which is #included in
<sgtty.h>; t_intrc is an element of (struct) tchars.  These definitions
are entirely missing in the SunOS 5.4 version of <sgtty.h> which does
not #include <sys/ttold.h>.
Am I correct in assuming that this is the root of the problem?  Should
I add #include <sys/ttold.h> to the preprocessor directives in
intr_char.c?  If so, why wasn't this done in the source code prior to
release?  The fact that it wasn't makes me suspect that this is not a
good solution.
Can anyone who has successfully compiled GRASS under Solaris 5.4 tell
me how to fix this?  Are there any other surprises in store?
Michael Camann                  camann at dial.pick.uga.edu
Department of Entomology        camann at sparc.ecology.uga.edu
University of Georgia           (706) 542-2303 voice
Athens, GA 30602                (706) 542-2640 FAX
