ps.map 24 bits
ALOBO alobo at ija.csic.es
Mon May 8 08:00:00 EDT 1995
"""ps.map prints in 24-bit, as long as your printer supports it."""
Are you positive? I look at the ps file with ghostscript prior to
printing and the image does not look the same quality that when the rgb
file is displayed with a program with 24-bit display (i.e., Multispec).
Is d.rgb generating a 24-bit image? Maybe the problem is there.
Thanks for your help.
Agus
