Color Palettes
Rick Thompson
rick at cast.uark.edu
Sun Nov 12 07:00:00 EST 1995
Hi Jim,
The quickest test I would use with r.colors is to take a simple raster map
with a single category and with r.colors do this:
r.colors map c=rules
> 1 brown
> end
Next, look at the rgb value placed for the brown in the $LOCATION/colr/map file
(brown is 191:127:63)
For a tan, you'll probably add values to green. Try 191:177:163 (add 50 to
green). Redisplay the map to check your results. Once you like the tan you've
developed, go to your original multi-category raster map and:
0 black (if you want it black)
> brown
> tan
> end
Another somewhat longer route would be to use d.colors where you can
interactively change rgb values. Hope this helps. Rick
On 12 Nov 1995, James A Theriault wrote:
> I've been playing with coloring rasters lately. Essentially, I'd
> like to re-color a map using tan through to dark brown colors
> in order to overlay rasters using other colors. I't apparent
> that I can do this using r.colors and specifying the type to
> be "rules."
> The difficulty that I've run into is finding a set of RGB values
> for a tan-to-brown color scale. Does anyone have any suggestions
> where to get a set of values that I can start with?
Rick Thompson- Research Specialist E-mail: rick at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-8498
Ozark Hall Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
