ps.map - changing background color
Ronald Wiemer
RWIEM at archis.nl
Tue Oct 24 08:00:00 EDT 1995
> I am trying to create a postscript file, using a region that is larger that
> the raster map I want to plot. The raster map is a satellite image (created
> using i.composite. I want to have a white background above (and around) the
> image so I can have text above the image (not in the image). The ps I do
> create with this image always has a black background, so I have to create
> white text so it will show.
> Is there something I can easily do in ps.map to have the background white?
> The only other way I can think of is to set the region to the size I want,
> then run r.resample, and use the resampled image in ps.map? Surely there
> must be a better way.
Try setting category value 0 to white using d.colors.
Ronald Wiemer
