ps.map, hp650c's and paper wasting
Ronald Wiemer RWIEM at archis.nl
Fri Oct 6 08:00:00 EDT 1995
> Do remember to edit the file if you're going to use A4 or A3 sized
> sheets, because the standard version of add.pagesize includes a 200 pixel
> wide left and top margin to the original postscript file, which is quite
> a lot on a small sheet. By the way, the problem seems to be HP: there is
> no such command as 'pagesize' in the original PostScript language, but HP
> printers which read it expect the pagesize to be included.
> Philip Verhagen
Unfortunately there is not one simple Postscipt language.
Encapsulated Postscript and Display Postscript are not exchangeable
and both exist in many varieties.
Device dependent statements are part of Postscript and nescessary
for any Postscript device that has more then one output possibility,
be it several papertrays or papersizes, but are forbidden in Display
Postscript, which is incorporated in Solaris.
So if you think you can produce Postscript and you have Software that
can read it, I can guarantee you that it will not work.
So when e.g. Coreldraw! says it can import Adobe Illustrator EPS
files, it can ONLY import EPS from Adobe Illustrator and nothing else.
In fact we are lucky that ps.map produces a kind of Postscript
that is readable, printable en displayable on some systems. Have you
ever looked at Postscript that comes out of MS-windows??
Ronald Wiemer
PS
The paper margins are settable from the frontpanel of the HP 650C
plotter.
