measuring area
Lars Schylberg
larss at fmi.kth.se
Fri Oct 13 04:53:14 EDT 1995
> Hi all,
> I have a situation in which I am trying to extend (grow) the
> area of a patch in a particular direction, depending on the ajacent
> cell. I want the patch to grow only untill it gets to a specified size
> ( say 20 Hectares). The trouble I have is stopping the growth. I have
> managed to get the patch to grow by identifying potential growth areas
> and runing the script below
> I would appreciate any suggestion.
> Thanks Joe
You have to run a r.stats once every loop to determine the size of the
patch growth. The result, the area you filter out with awk from the
r.stats command. That value is assign to a variable that You use to check
for ending criteria in the while loop.
Here is the principle:
SIZE=`r.stats -a output | awk 'pattern plus right column'`
Good luck
Lars
Lars Schylberg Email: lasc at celsiustech.se
CelsiusTech IT or: larss at fmi.kth.se
S-175 88 Jarfalla Tel. +46 8 580 847 03
Sweden Fax. +46 8 580 123 20
