Reply to: HELP needed with d.3d.and i.points
/S=J.SCHMIDT/OU1=R05F16A at mhs-fswa.attmail.com /S=J.SCHMIDT/OU1=R05F16A at mhs-fswa.attmail.com
Fri Oct 20 07:41:12 EDT 1995
Date: ## 10/20/95 07:41 ##
Regarding prints of d.3d in Linux - I've not been able to get the
CELL driver to work, so have been using an X-windows dump (xwd), then
using the pbmplus utilities to convert to ppm format and then to gif.
I use Corel PhotoPaint or Micrografix PhotoMagic to edit and
print.
Jim Schmidt
avenues at sonnet.com
Date: ## 10/19/95 19:25 ##
From:    C=US/ADMD=ATTMAIL/ORG=ATTMAIL/PN=Eliot Michael Cline/
         DD.ID=internet(b)ksc.net.th(b)ecline/
Is screen capture the only way to save the image produced by d.3d to a
file? If so, what is the best program for doing this? (I am running GRASS
under Linux)
When using the program i.points my images in 256 colors/greylevels seem
to get pared down to 16 or some such amount. So much information is lost
I can't effectively choose points to use with i.rectify. This is the case
whether I am in fixed or float colormode. Is there a way around this?
Any help would be appreciated,
Eliot Cline
