r.combine - never mind.
Casey Claiborne mskc at io.com
Mon Sep 4 09:59:51 EDT 1995
Hello -
        I found the answer in the manual :-)  So - never mind.
>Hello -
>       This question is with reference to r.combine. I know that it can take
>a file as input and that it will send output to a certain monitor or the
>screen. Can it send the results to an output file and can I use GRASS
>to view that output file?
>TIA
One must note the importance of setting reasonable and achievable goals for
                    "If you aim for nothing, you'll hit it every time"
                               -Theodore Roosevelt
