creating a surface with an ascii file
Daniel Rodriguez danr at rsgis5.tamu.edu
Wed Dec 4 16:53:29 EST 1996
I have an ascii file which contains N,E,elevation_value,ID.
What is the best way of creating an surface from this file.
Should I create a point coverage first then a tin.
I know you can a surface from contours lines using r.surf.contour.
						Thank you
						Daniel H. Rodriguez
