Grass 4.1 in Linux - Error on run, Ideas ?
Lawrence Houston grass at boyd.geog.mcgill.ca
Mon Dec 9 13:37:53 EST 1996
On Sun, 8 Dec 1996, Linux Weenie wrote:
> Got it installed ok, blah blah.
> Figured grass would be good since it can import different formats.
> On run I get the error:
> /usr/local/grass/etc/gis_set: can't resolve symbol '__waddbytes'
> I see no way to edit gis_set :)
> Am I looking at an edit Makefile and re-compile ?
When using Kang's 4.1.5 ELF Binaries I had to install the Curses Library
seperately, due to it NOT being included with the recent C Libraries (it
used to be).  Without the Curses Library I get the following message:
     /usr/extra/grass4.1/etc/gis_set: can't load library 'libcurses.so.1'
Where it is also "gis_set" which is complaining, but a slightly different
message!  NOTE: "__waddbytes" is defined in the Curses Library V1.0?
Lawrence Houston  -  (grass at boyd.geog.mcgill.ca)
