Graphichs Monitor Problem
Lawrence Houston grass at boyd.geog.mcgill.ca
Mon Dec 30 13:32:08 EST 1996
On Mon, 30 Dec 1996, Henning Brockfeld wrote:
> Lawrence Houston wrote:
> > The "standard" GRASS 4.1 XDRIVER ONLY works with X-Servers running in
> > 8-bit (256 Colour Mode).  The above probably indicating that you are
> > running your Red Hat 4.0 Server in a 15/16 or 24 bit Colour Mode?  Moving
> > back to the 8-bit mode should get GRASS's XDRIVER working for you!
> The question is: Is there a patched version of XDRIVER which supports
> 15/16 bit colour mode? This seems to become a FAQ in Linux environments.
Henning:
On 8 Apr 1994 Kenn Gardels <gardels at ced.berkeley.edu> makes reference to
24-bit patches being available as part of their Alpha Port:
     ohlone.ced.berkeley.edu:/pub/grass
Again on 16 Feb 95 Kenn makes reference to the Alpha patches, but this
time ONLY mentions contacting him via E-mail?
On 17 Feb 1995 Andreas Schmidt <schmidt at ipf.bau-verm.uni-karlsruhe.de>
reports that Kenn's 24-bit patches work under SunOS (24-bit display) and
Linux (24-bit & 16-bit displays).
Not sure if the "patches.xdriver.24bit" patch contained in
"grass-alpha-axp-0.6.tar.Z" is the most recent (Mar 25 1995), your might
want to check with Kenn on that.  Additionally I have NOT tired these
patches myself (ONLY kept the GRASS Hopper Posting related to them), but
reportedly they allow for an 8-bit XDRIVER Window to operate on a
16/24-bit display.  Hope that helps?
Lawrence Houston  -  (grass at boyd.geog.mcgill.ca)
