v.in.arc
Eric Small esmall at rupture.ucsc.edu
Thu Feb 15 07:00:00 EST 1996
Hi.
I am using Grass 4.1.
I am trying to import an ARC/INFO vector file into GRASS
and then create a raster file.
I am able to bring the ARC/INFO file into GRASS with v.in.arc.
However, every time I try to use v.support to build the topology
information (so that i can use v.to.rast), i get the following
error:
sh: 5132 Memory fault
ERROR(v.support): Could not build vector file: 'filename'
(the number 5132 changes each time)
The same thing happens when I use v.support on any files,
even vector files made in GRASS from GRASS rasters.
Is this a common probelm ? How do I fix it ?
Thanks,
Eric Small
