vect polygons to MapInfo
Xin Zhuang zhuang at access.digex.net
Tue Jan 2 07:00:00 EST 1996
Thanks, Ron.
I'll take a look at your code. I have written a code
that has solved the problem of shared boundaried, as
I tested. I do have a problem to take concaves into
GRASS, which I didn't have time to work on it yet.
BTW, does youe code take care of concaves? For me I have
a problem to identify a point within the concave that required
by GRASS, if I understand GRASS correctly.
--Xin
In info.grass.user you write:
>> Has anyone done this before? Since MapInfo
>> needs a polygon/region self-contained
>> no matter where it shares boundaries with
>> others or not, it won't take GRASS vector
>> polygons exported in v.out.ascii?
>Hi,
>I have put a program called v.out.mif on the incoming directory of
>moon. It makes a mif and a mid file from a grass vector map (polygons
>only).
>The resulting files are stored in the directory $LOCATION/mapinfo.
>If you have rasterized the vector map with grass and you have
>assigned colors to the different categories you can use this raster
>map to color the exported vector map.
>The header of the mif file contains information on the projection
>and type of coordinate system used. Since I only use the Dutch
>coordinate system, you will have to edit this if you want another one.
>The coordinates are written in the format %10.1lf If you need another
>format, edit the source.
>MIF files can also be imported into Arc-View. There is a tool
>MIFSHAPE, which converts MIF-files to Arc-View SHAPE files.
>Wish you all good luck and best wishes for 1996
>Ronald Wiemer
>R.O.B. / ARCHIS
>kerkstraat 1
>3811 CV Amersfoort
>The Netherlands
